03 Accent - Change High Mount Brake Light Bulb??
Old 01-05-2009, 08:20 PM
crisko's Avatar
Default 03 Accent - Change High Mount Brake Light Bulb??
Has anyone here ever changed the high mount brake light bulb in an accent? I unscrewed the 4 screws on the base of the light cover near the window, however it doesn't seem to do a whole lot. Reading up on the Hyundai service website, I can't seem to find any info on changing the light bulb. They have a DIY for taking the entire light assembly out (requires the trunk lid trim be removed, remove 5 bolts, disconnect wires, remove 4 screws, etc...) but I can't imagine it would be that complicated just to change a bulb... is it?? Any help appreciated.. thanks.
Old 01-06-2009, 04:35 AM
jsinton's Avatar
Banned
Default RE: 03 Accent - Change High Mount Brake Light Bulb??
Yeah, that's what it says, it's not really that hard:
1.Disconnect the negative(-) battery terminal.[/align]2.Remove the tailgate trim.[/align]3.Remove the 5 bolts, disconnect the wire connector and then remove the center high mounted stop lamp.[/align]4.Installation is the reverse of removal.[/align]
Lmar1
02-02-2019 02:57 PM
lavangbay
05-21-2011 07:13 PM
duce
02-04-2009 07:22 PM
hawzmolly
12-20-2007 02:47 PM
Accentcrazy
10-10-2007 09:53 PM
Quick Reply: 03 Accent - Change High Mount Brake Light Bulb??
