2000 hyundai has no spark
Old 01-21-2009, 01:16 AM
toad33's Avatar
Default 2000 hyundai has no spark
Driving to work, car shut off with check engine light on. Made it to Autozone next day and the code said it was the crank sensor. Had to order it and when I put the new one in the car ,would not start. I put the original one back in and it would start. I repeated this 3 times and after the last time I put the original one back in, it would not start. I checked the spark and doesn't have one.I had a spare 2000 motor and replaced the cam sensor, coil pack and module and I replaced the crank sensor with 3 different ones. Checked the fuses and all OK. Took it to a garage andeven had a hyundai tech look at it and can't figure it out. Need Help
Old 01-21-2009, 05:42 AM
jsinton's Avatar
Banned
Default RE: 2000 hyundai has no spark
When you take the old sensor out, sometimes the rubber gasket will remain in the hole. When this happens, and you put the new one in with a new gasket, it holds the sensor too far away from the crank to get a signal. So the question is:
When you took the old one out, did you look inside and verify that all the old gasket was removed too?
If so, what was the code you got?
Old 01-21-2009, 10:49 AM
toad33's Avatar
Yes I did check the o ring.There's just one. and there's no code as of right now.
Old 01-21-2009, 04:04 PM
jsinton's Avatar
Banned
Need to know the actual code you got to verify. Sometimes the crank sensor gets confused with the cam sensor, even the Hyundai repair manual got it confused. If you replaced the crank sensor thinking it's the cam sensor (or visa/versa) then that's the problem.
Old 01-21-2009, 11:20 PM
toad33's Avatar
Sorry I don't have the code. I did change cam sensor with a differnent one.It was off a 2000 motor.
Old 01-22-2009, 05:14 AM
jsinton's Avatar
Banned
Get a code scanner and see if there is some codes now. Obviously something is REALLY not working, there should be a code. I'm not sure, but I think Autozone will lend you a scanner for free.
mark0006
05-26-2015 12:54 PM
daesimunda
07-11-2008 01:14 PM
mrbill
07-31-2007 06:27 AM
andrews65
11-26-2006 09:57 PM
Quick Reply: 2000 hyundai has no spark
