2013 Accent blinker problem
Old 03-30-2016, 12:30 PM
thedoctor63's Avatar
Default 2013 Accent blinker problem
I have replaced my front, driver side blinker bulb 3 times, yet it continues to blink rapidly and is dimmer when my lights are on. Is there a fuse I can check or a special kind of bulb I should try?
Old 04-01-2016, 07:45 AM
Need more info. Is the rear turn signal bulb blinking fast too and just the front one? Does the rear one blink at all or normal. What about he passenger side? Do you have LED bulbs in either?
Old 04-01-2016, 09:45 AM
Default Blinker
Need more info. Is the rear turn signal bulb blinking fast too and just the front one? Does the rear won blink at all or normal. What about he passenger side? Do you have LED bulbs in either?
Passenger blinkers work fine and yes, the rear blinker, which I thought to replace as well, also blinks rapidly. Replacing the rear blinker didn't correct the problem either, so now I'm wondering what I can try next. There are no LED bulbs in either.
Old 05-15-2018, 06:27 PM
medium1's Avatar
It not the bulb the problem is the bulb holder connection. Just spray wd40 on the connectors (3) and the rubber gasket ( to make installation easier). I have to do this every 6 months or so.
lizziedunn
03-07-2016 04:18 PM
Azbrokeer
11-09-2013 09:55 PM
wicked5.0
03-13-2011 04:26 PM
gumby25
08-24-2010 06:42 AM
Jon
07-23-2010 09:28 PM
Quick Reply: 2013 Accent blinker problem
