Which coolant for a flush on a 2001 Elantra 135K miles?
Old 11-10-2008, 03:51 PM
ken2400's Avatar
Default Which coolant for a flush on a 2001 Elantra 135K miles?
Which coolant should I use for a 2001 Hyundai Elantra GLS with 135K miles
Thanks
Old 11-11-2008, 06:44 AM
jsinton's Avatar
Banned
Default RE: Which coolant for a flush on a 2001 Elantra 135K miles?
I think you just need a 50/50 mix of plain old ethyl glycol, the green stuff. Flush out your system with a garden hose, turn on your heater when you do it. You're supposed to change it every two years according to some mechanics.
Old 11-11-2008, 07:17 PM
ken2400's Avatar
Just what I did.
Things to note. I should have done it when it was hotter. I can only pull out like 2 qts at a time. 6 is what the books says. So I pulled and just added water.
Then run it around a bit and did it again.
Will keep track of level and concentration. Most of the time it is too high or too.
Also the fan ran more than it should. Not when it first started but time when I think it should be off. The AC was off all the time I noted this.
It seems better BUT need to put more miles on it.
Mr. Pine
10-05-2011 03:40 PM
zachunderwood
12-18-2010 08:17 PM
W3MOT
04-21-2010 02:27 PM
luvmycarbut
02-08-2010 04:53 AM
JGeZau
10-31-2005 07:43 AM
Quick Reply: Which coolant for a flush on a 2001 Elantra 135K miles?
