engine die randomly while driving on the road and hard starting in morning
im driving a hyundai matrix (Lavita) 2004 automatic trans,. 1.6 liter engine GAS.. 1st in the morning,.it so hard to start,,trying over and over again and luckily it start about 10x before it is start,.then,.after that,.randomly when im driving in the road,.there a times that my engine shutoff/die and it hard to start again but after a few try luckily it will start well,.what the problem of my car?..2nd at the paking,.when engine is on,.ill check the fusebox suddenly when i make a sudden movement to the fusebox,.the engine shutof again,.next i start the engine on again,.when im closing the hood doorwith a force,.the engine die again,.what seem to be the problem of this car?
It is difficult to understand your problem.
But, it sounds like a wiring problem with the fuse box.
For that you must take a visual inspection of the wiring and see if there is something loose or frayed.
Good luck to you
Good luck to you
02sonata
03-25-2010 02:13 AM
