H1 no power
H1 no power
Hello I have a problem with a 2009 2.5 Hyundai H1 turbo diesel
The vehicle has absolutely no power ,the engine will not rev above 2000rpm there is also large quantities of soot coming out the exhaust
There are no logged fault codes
I have removed the turbocharger and inspected all looks ok
Checked exhaust system for blockage all ok
Started up vehicle with exhaust manifold off excessive smoke coming out of no 3 exhaust port when pushing accelerator
swapped diesel injector problem still present on no 3 cylinder
Compression tested no 3 cylinder 350psi
Bit stuck now any help would be awesome
Regards Blue
Regards Blue
Regards Blue
Regards Blue
Did you manage to solve the problem i would like to know what was the problem, as I'm having the same problem
Regart WDJ
H1 no power
Regards Blue
Regards Blue
Regart WDJ
