Help,
Help,
size=4][/size]I have a silver 1998 tibby 2.0, and I am having a Problems,the main problem now is my brights do not work, I checked the bulbs , they appear to be fine, the switch is working accroding to the hud, the only thing is the fuses under the hood, how do you check them big black ones, the 15 amper under the hood is fine. any suggestions??
RE: Help,
The big black ones are the relay, using a circuit tester test if power is going to the relay if so pop down to ur nearest auto store, relays for most cars should cost around $29.95, if u find an auto store that gives refunds if the item isnt required give that a go and test if its it or not
RE: Help,
I've had a similer problem in the past on my 98 tibby the head lights would not come on at all. So what I did was get the wiring diagram and found that it was the thermal overload protector located under the under hood relay box was burnt out so what I did was get a new one and it cost me only $1 and its been working fine ever since.
hope this helps
hope this helps
