How to reset tire pressure light?
Old 05-07-2008, 03:42 PM
hycustomer's Avatar
Default How to reset tire pressure light?
How do you reset the low pressure light and/or the tire pressure monitoring system [TPMS] light?
Thanks!
Old 05-07-2008, 07:28 PM
Default RE: How to reset tire pressure light?
What do you mean by reset? If the tire was low and you added air, the light will go out by itself. If the sensors have been off he vehicle for a while, the computer "forgets" them and need to be re-added. TO re-add the sensors, you have to go to the dealer. They are only added with a Hyundai Scan Tool.
Old 05-07-2008, 10:29 PM
hycustomer's Avatar
Thanks, NovaResource. Our previous car [Buick]had a 'reset' button that had to be pushed in order to remove the low tire pressure light. We checked the manual w/our Sonata; nothing was said about how to get the light off after airing up the tire. Sounds like when we start it up again, it should be off. Thanks for the head's up. It takes a bit to get used to a new make.
Old 05-08-2008, 07:12 AM
OK. No, you should have tto reset the TPMS system if the tires are all inflated correctly. The light should go out within a mile or two of driving. If it doesn't, have the dealer look at the system.
HermanPWillis
09-20-2011 07:32 AM
BREWSTER
09-08-2009 08:51 AM
gunwaleman
08-21-2009 07:10 PM
085speed
07-17-2008 05:19 PM
marcbla
02-24-2007 10:53 PM
Quick Reply: How to reset tire pressure light?
