PO446 code and Misfire @ 2,4, and 6
Old 02-11-2006, 11:30 PM
pete4117's Avatar
Default PO446 code and Misfire @ 2,4, and 6
What is the main problem with trouble code PO446? Emission control?
I also have a misfire problem @cylinders 2,4,6. I have replaced the wires and plugs!
Thanks in advance!!!!
Pete
Old 02-13-2006, 06:31 PM
Patrick's Avatar
Administrator
Default RE: PO446 code and Misfire @ 2,4, and 6
is the emission control problem minor or gross? if its minor evap leak, its probably a bad gas cap.
Old 03-12-2006, 10:42 AM
slimone's Avatar
Hi , My 04 sonata gets a p446 code also , my dealer says it because I drive on a dirt road, any way there is a small filter inside the left rear fender bolted to the filler pipe ,it picks up the dust from the rear tire , I clean it each time I change oil ,(once a month) and that takes care of the PO446 code . You need to remove the plastic inter fender panel to get to it ,not hard to do, as for the missfire check plugs , good luck Slimone
ricks98ws7
05-25-2017 10:36 AM
kittehs4peace
01-11-2011 11:16 AM
blackbox19
08-06-2010 09:59 PM
pete4117
02-14-2006 08:04 PM
slimone
07-28-2005 12:51 AM
Quick Reply: PO446 code and Misfire @ 2,4, and 6
