transmission sensor help.
ok thanks for that info. here is the problem. i have 2 transmissions. one bad one good. they r from the same year, within the manufacture dates they need to be to match up, but the bad one has a 4 pin solenoid harness and good one has a 6 pin solenoid harness. can i change the two around and how do i remove them? everything else matches perfectly.
james92se
01-18-2011 07:50 PM
