Accent 1996 Fuse Diagram
Old 10-29-2009, 12:52 AM
Jalalwr's Avatar
Lightbulb Accent 1996 Fuse Diagram
Deal All,
I have Accent 1996 and i need the fuse Diagram which i have it in Korean language and can't understand anything..
could you guys help me?
thank you
Old 10-29-2009, 06:20 AM
ENGINE COMPARTMENT FUSE/RELAY BOX
Located at the left front corner of the engine compartment.
DASH FUSE BOX
Located below left side of instrument cluster at the kick panel.
Fuse Amperages Circuits
1 10A A/C compressor controls
2 10A Anti-lock brake system
3 10A Turn/hazard lamps
4 15A Interlock system, Stop lamps
5 10A Instrument cluster, Clock, Radio, Dome and trunk lights, ECM, Ignition key switch
6 20A Rear defogger
7 15A Rear wiper/washer
8 15A Wiper/washer
9 10A Back-up lamps, Turn/hazard lamps
10 10A Instrument cluster, Interlock system, Seat belt and ignition key warnings
11 10A Supplemental restraint system (SRS)
12 15A Supplemental restraint system (SRS)
13 15A Cigarette lighter
14 10A Radio, Clock, Interlock system
15 10A Automatic transaxle
16 10A Blower relay, H/Lamp relay
PASSENGER COMPARTMENT RELAY BOX
Located behind the left side of the instrument cluster.
Old 11-01-2009, 01:16 AM
Jalalwr's Avatar
Thank you very very much
i will print it and try it, i believe this diagram is 100% correct but i need to be sure of it
thank you man you are the best..
ediushu
07-17-2013 09:55 AM
jhilborn
07-20-2011 11:23 AM
ModelPOS
09-14-2010 12:59 PM
Tonyaloveshyundai
06-04-2010 07:03 PM
eddie_boy
06-25-2009 12:27 PM
Quick Reply: Accent 1996 Fuse Diagram
