Brake pads selection
Old 09-20-2006, 02:02 PM
Majki's Avatar
Default Brake pads selection
Hello,
I have 2002 Accent and thinking of getting some pads that will last longer. My background is in mechanical engineering and I wonder why pads that are lets say of ceramic or kevlar are advertised without proper rotors? My guess (although I am not completely sure) is that, if I would put kevlar pads on regular rotors, my rotors would be gone much sooner than pads. Is my assumption correct? I wish to put pads that will last longer and provide better stopping power but on the other hand I don't want to end up changing rotors more frequent than pads.
Thanks in advance,
Majki
Old 09-20-2006, 02:12 PM
Robinsontc's Avatar
Default RE: Brake pads selection
ORIGINAL: Majki
Hello,
Thanks in advance,
Majki
To play it safe use the same type of pad that is called out.
Pads are cheaper than rotors. Putting on a metallic when a semi-metallic is called for will wear down the rotors very quickly but the pads will last longer.
A dealer part is the best, although I have used Raybestos and they are very good drop-in replacements.
TommyR
janmarsh
11-04-2011 05:10 AM
tinskeep
03-05-2011 06:36 PM
tinskeep
01-09-2011 08:38 AM
steve1959
09-09-2006 12:23 PM
marauder
08-10-2006 12:10 PM
Quick Reply: Brake pads selection
