Enginethings please help
I'm having trouble finding the name of a part. It's located near the wipermotor. Check engine light is on (P0422). I also want to know if I my ignition wires Are connected in the correct order.
If you google for P0422 it comes up as "Code P0422 indicates that the Bank 1 Main Catalytic Converter's emissions efficiency has fallen below the minimum allowable limit. This threshold is tracked by a Catalyst Monitoring Oxygen Sensor located on or near the outlet of the Catalytic Converter."
The other thing i have no clue what you talking about you got a picture or more precise description?
what model/year of the car?
It's an accent 99 lc. I'll take a picture of the part i'm asking about asap ^^
If i were you i'd test 02 Sensor resistance with digital multimeter to see if its okay or just get a new one however might worth testing they are pain in the *** to unscrew.
I think its evaporation system solenoid used in returning vapors from gas tank to be burned inside engine, if you take it off which is easy then you can read the part number and put # trough google it will show you what part it is exactly.
It might give you check engine code if not working however its very optional and would not affect the engine operation.
This is how ignition wires were on my car, but reference the manual to be sure google for "manual-de-despiece-hyundai-accent-98-1.5-SOHC pdf".
