Go Back   Hyundai Forum - Hyundai Enthusiast Forums > Vehicle Line Up > Hyundai Accent
Sign in using an external account
Register Forgot Password?
Search
Reply
LinkBack Thread Tools Search this Thread
Old 01-25-2011, 07:09 AM
Default oil light on
I have an 02 accent with the 1.5. The oil light in the dash is on all the time but the oil level is good and the riding temp is normal. I'm assuming that is a bad oil pressure sensor...but where is it in the engine....
Thanks for any help on this matter!
Sponsored Links
Old 01-25-2011, 09:05 AM
2006 Hyundai Tucson
My Garage
Don't assume that. I'd assume the sensor is correct and that the pump is bad. Once you verify the pump is creating pressure and oil is flowing then you can assume the sensor is bad.
Old 01-25-2011, 04:24 PM
how do i check the oil pressure and where is the sensor?
Old 01-25-2011, 09:16 PM
You verify oil pressure using a mechanical oil presure gauge..
After verify pressure is indeed there and correct at idle and speed, then we can assume sender or switch is at fault...
The engine does have good clean oil in it, a quality oil filter (preferably Hyundai filter)..
The oil pressure sender/switch is on radiator side of engine block I think.
Reply
Tags
02, 0il, 2006, accent, bad, flash, huyndai, hyundai, light, normal, oil, pressure, sensor, switch, tucson
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
