Hyundai Atos Predominantly sold in Europe, the Atos is the smallest of the Hyundai lineup offering European sub-compact styling.
Atos Check engine Light and power loss.
Old 10-03-2012, 02:47 AM
Luffarrock's Avatar
Default Atos Check engine Light and power loss.
Hello,
My wife has a Atos 00' GLS that is acting a bit weird. When she drives it to work in the morning it temporarily feels very jerky and like it looses power, check engine light flashes and then it's ok again. Now the check engine light is on constantly though the car is only jerky in the morning when it's cold.
We had it checked at a hyundai garage and it was recommended we change the spark plugs and ignition wires, which we did. This did however not fix the problem.
thankful for any ideas on what could be the cause.
Old 03-07-2013, 05:47 PM
GeraldV's Avatar
Default Power Loss
Originally Posted by Luffarrock
Hello,
I realise this is a very old post, but possibly this may help someone else.
Have the cambelt sprocket on the CRANKSHAFT checked. It is known to wear out and develop play. This results in valve and ignition timing to go out resulting in power loss.
The Atos engines are prone to this problem.
Old 03-08-2013, 02:32 AM
Luffarrock's Avatar
Thanks for the reply Gerald
Old 09-04-2013, 05:48 AM
Ricardo Jorge's Avatar
I have the same problem. Can you tell me if you fixed the problem?
I've taken the car to 2 difente mecanics and they cannot find the any problem.
Cheers.
Old 09-05-2013, 02:57 AM
Luffarrock's Avatar
Hello,
We have in fact not fixed it ourselves. We recently had a new cambelt put in and we had the mechanic check the cambelt sprocket as previously suggested and it was all ok according to him.
The only other clue we have is that quite a common problem on the early Atos is a chip in the electronics box that malfunction and causes this problem, apparently a cheap fix.
Car seems to behave very well though appart form the temporary jerking in the morning.
Old 12-11-2013, 06:18 AM
Luffarrock's Avatar
We finally got it sorted so I thought I´d share my solution. It was the MAP sensor that was malfunctioning, nothing about this when i checked the error codes, all i had was missfire on random cylinders.
Anyway, replaced the MAP sensor and all has been fine since. They are a bit tricky to source online but you can find one on Ebay for about Ł70, i bought a second hand one for Ł20, dead easy to change takes about 10 minutes to loose 2 bolts and a wire, bear in mind the sensor got an O ring so have some engine oil handy.
See photo below, it´s the sensor circled in top, number "2"
http://obrazki.elektroda.net/15_1215845879.jpg
Old 07-16-2017, 10:30 AM
Dirk van den Brink's Avatar
Default Similar issue BUT...
Same symptoms. ‘01 Elantra. Loss of acceleration and power steering, oil, battery, and check engine lights on. Thing is, the engine is not stalled. It’s still running. Sounds like an elecrrical issue with the computer, and less like an ignition, timing or MAP sensor issue. Someone said something about a “chip” earlier (assuming you’re referring to the computer). Care to elaborate? I don’t want to start chasing things in this heat if someone else already has the answers! Thanks in advance!
Old 07-17-2017, 12:38 AM
avisitor's Avatar
Did you scan the ECU for Diagnostic Trouble Codes?
Format is PXXXX
For example, P0300 is for random misfires
marua_KP
04-20-2015 09:58 PM
nickaz2013
08-18-2013 12:14 PM
glkpierce
10-25-2010 02:12 PM
larry l
08-09-2010 02:04 PM
lampadinac
10-30-2009 02:40 AM
Quick Reply: Atos Check engine Light and power loss.
