Hyundai Atos Predominantly sold in Europe, the Atos is the smallest of the Hyundai lineup offering European sub-compact styling.
T Reg Hyundai Atoz won't start after break in
Old 11-06-2013, 10:37 AM
Simzter's Avatar
Default T Reg Hyundai Atoz won't start after break in
Hi
Our T registered Hyundai Atoz was broken into.
They have snapped the steering lock, all the wires look intact - however the vehicle won't start.
The car actually turns overs when the key is turned - however this only lasts for as long as the key is turned as far as possible (to the spring) - when released back the engine cuts out immediately
The cap (on the left hand side of the steering column) hasn't been damaged - however on the plastic on the right hand side where the key goes in (which says lock/start etc) was torn away from the metal - and snapped in two.
This has two wires - a black and a white one - which are still intact.
The half that has the wires - appears to have two metal pins/prongs sticking out - I have pieced the two pices of plastic together - as there appears to be a place for the prongs in the 2nd half.
Does anybody have any experience with these - and if the black and white wires are something to do with it?
Old 01-08-2015, 08:32 AM
waynewep's Avatar
The item around the ignition switch is a key reader and is part of the factory fitted security system. If this is broken, the built-in immobilizer system will not allow the car to start. In order to repair this, it will need to be replaced and coded so either a workshop with the correct Hyundai diagnostic software or a dealer.
Josh Clinard
11-09-2013 05:00 PM
Regann
01-15-2013 04:36 PM
Robert
10-19-2008 11:08 AM
andypandy56
08-30-2007 01:37 PM
canehdien
12-30-2005 02:44 AM
Quick Reply: T Reg Hyundai Atoz won't start after break in
