Hyundai Azera A Hyundai like you've never seen before.
TPMS Reset
Old 10-30-2008, 06:06 PM
trom1's Avatar
Default TPMS Reset
Hello my friends.Well my AZERA just turned over 10,000 and all is well.I bought chrome rims for it and when you switch them,the TPMS lightcomes on.Can you Reset at home without a plug in device.Any Help would be Great with this dilemma.Thanks and Please Respond
Old 10-30-2008, 09:28 PM
ken99's Avatar
Default RE: TPMS Reset
If you purchased TPMS compatable rims and had the wheel sensors transferred from the old rims, the system shoudl reset itself unless you are running a lower air pressure in the tires. The TPMS will trigger at pressures about 25% below the recommended pressure listed on the label on the drivers door pillar for any one tire.
Old 11-01-2008, 07:09 AM
trom1's Avatar
Hello Ken,Rims are Hyundai factory and sensors are Hyundai New.Tire pressure is the same as before.Thanks and Please Respond
Old 11-01-2008, 09:44 AM
ken99's Avatar
There are a couple of issues that could be the problem. There is a TSB for the TPMS sensors and system for the Sonata (http://jerrystout.us/sonata/tsb/tpms_mode_setting.pdf), that could also apply to your Azera. You don't say which year your Azera is, but if a 2008 or older and the Dealership sold you new sensors, they may not be compatable with th old system. Also, the dealership will have a special scan tool (TPMS Exciter) that can sort out these problems. I think you need to take the car back to the dealership to resolve this matter.
If the new sensors are compatable, they have to be registered with the TPMS system using the TPMS Exciter scan tool. That is most likely the situation you have.
Old 11-03-2008, 04:41 PM
trom1's Avatar
Dear Ken,Thank You for your time.I will take it to the Dealer.
tabsonata
11-25-2007 08:51 PM
mikibark
08-12-2007 01:46 PM
wifes_santa_fe
07-11-2007 04:06 PM
carlibobarli
03-24-2007 10:57 PM
Captain Mark
02-13-2006 12:06 AM
Quick Reply: TPMS Reset
