1999 Hyundai Elantra
Old 11-30-2011, 07:00 PM
Fireknight's Avatar
Exclamation 1999 Hyundai Elantra
When I go to take off the car is very sluggish, when I shift I have the same problems. As long as the RPM's are up everything seems fine. I plan on changing out the fuel filter tomorrow, but if anyone else has the solution to my problem I would be grateful!!
Old 12-01-2011, 02:43 AM
Fireknight's Avatar
Default Also
After talking to a friend he thought that it might be the Throttle Position Sensor (TPS). It only costs 50$ so that would be great and it is easy to install so that would be great that and a fuel filter! haha.
Does anyone have anything to add? I am going to hook up my ohmmeter and see if the TPS is in the green, if it is not I am going to replace it tomorrow (or put it on order) I will keep everyone informed of what is going on.
Thanks Everyone for your support and input!
Old 12-01-2011, 08:10 AM
HARNESS INSPECTION PROCEDURES
SENSOR INSPECTION
1.Disconnect the throttle position sensor connector.
2.Measure resistance between terminal 2 (sensor ground) and terminal 3 (sensor power).
3.Connect an ohmmeter between terminal 3 (sensor ground) and terminal 1 (sensor output).
4.Operate the throttle valve slowly from the idle position to the full open position and check that the resistance changes smoothly in proportion to the throttle valve opening angle.
5.If the resistance is out of specification, or fails to change smoothly, replace the throttle position sensor.
walterg6
08-29-2014 11:59 AM
djassisti
12-17-2012 05:28 AM
flynnerd
02-16-2011 02:31 PM
rwhit
05-27-2007 02:53 AM
lvtaxiguy
11-24-2005 12:56 PM
Quick Reply: 1999 Hyundai Elantra
