2005 Hyundai Elantra GT Caliper Guide Pins
I replaced my rear disc brake pads on the above car. I did not realize the two caliper guide pins are different, one is all metal and thick and the other is thinner at the bottom and has a ruuber sleeve on it. I did not notice which pin went on the top of the rear disc brake caliper. Can anyone tell me which pin goes where? Bruce
Here is a picture of the guide pins, these are replacement but my guide pins are the same. As you can see one has a tapered section the little rubber sleeve goes over. The bolts that are used are the same but I am questioning which guide pin goes in the top hole. The pins will fit in either hole. Bruce
