Light Replacement Trouble
Old 08-01-2011, 03:33 PM
JeffreyLewis03's Avatar
Default Light Replacement Trouble
I have a 2003 Hyundai Elantra and my low beams both went out at the same time. I replaced both bulbs and now the driver's side works but the passenger side does not work. I checked the fuses and they are ok. Also initially the high beams worked when the lows were out but after changing the passanger side low beam that high beam no longer works while the driver side still does. Any thoughs?
Old 08-02-2011, 02:31 PM
jrstroh_96's Avatar
Check your wiring. See if they have any signs or being hit cut or burnt. But you may have to check from the light to the main harness.
jasons_accent
07-31-2009 06:19 PM
duce
02-04-2009 07:22 PM
willidw
01-01-2009 10:34 PM
holt3332
10-08-2008 06:10 AM
ice963
12-26-2007 11:03 PM
Quick Reply: Light Replacement Trouble
