Dash warning light not listed
Old 10-02-2008, 07:28 PM
Sardot's Avatar
Default Dash warning light not listed
Hi, I have a 2008 Elantra and on the right side of the dash I have a dummy light that looks like a horseshoe with an exclamation point in the center. There is no such light listed in the owners manual. Does anyone know what this is for? Everything is working just fine with the car.
Old 10-02-2008, 08:00 PM
ken99's Avatar
Default RE: Dash warning light not listed
It the tire pressure monitoring system light. The feature is discussed on page 4-50, but you are right that the symbol itself was left out of the manual.
Old 10-02-2008, 10:02 PM
Sardot's Avatar
Thanks a lot! I did a walk around with that in mind because all other problems were listed with the lights. None of the tires looked low but I'll have to top them all off, may be a little bit sensitive. Thanks again, Jeff
Old 10-03-2008, 06:34 AM
Yep, Tire Pressure Monitoring System. One or more of the tires has low pressure.
Old 10-25-2008, 07:35 PM
ken2400's Avatar
SOMETIMES one can tell by looks BUT get a tire gage out and KNOW what the pressure is.
Winter is the main season for keeping an eye on tire pressure.
If anything get below 25 lbs have the tire inspected, rim cleaned (sanded), and remounted in insure it keeps air.
Good luck and post back on your findings.
Thanks
Good luck!
ORIGINAL: Sardot
elantragtowne
12-02-2022 02:20 PM
daniel2229
03-08-2014 07:16 PM
tcarr925
08-18-2007 03:48 PM
2003 gls sonata
05-18-2007 06:30 PM
Swampy
02-17-2006 06:17 PM
Quick Reply: Dash warning light not listed
