How to replace transmission valve body?
Old 02-20-2007, 06:20 PM
MiguelMckaintt's Avatar
Default How to replace transmission valve body?
Hi everbody ,i am having some transmision shifting problems i went on hmaservice.com a site dedicated to hyundai techs, However the fault code that i got fron a scanner indicated a Pulse generator in the transmission valve body that has a short ,what i need to know is how do i remove the valve body what are the screws you remove i took apart the oil sump pan,and transmission filteralready, i would appreaciate if i could get some pic showing me which screws to remove thanks in advance.
Old 01-09-2008, 06:09 AM
keremaras's Avatar
Default RE: How to replace transmission valve body?
can you find how to replace got the same problem thanks
Old 01-09-2008, 11:17 AM
madindian1's Avatar
it's not in the transmission valve body. what year elantra do you have? well it said pulse generator so i'm assuming it's the older elan., the sensor is on the top and at the bottom side of the trans close to the oil pan. if it is the newer elan. then you can replace whichever one it calls for, input or output sensor.
Old 01-09-2008, 04:00 PM
http://www.hmaservice.com/
Signup and register, Find your vehicle under the shop link and some info is there on your valve body dissasembly/reassembly, etc.....
Or buy a haynes menu
shigitysxse
03-10-2011 01:50 PM
HangingAround
09-10-2009 02:47 PM
jboucheb
12-08-2005 07:44 PM
mydartswinger
05-28-2005 04:42 PM
Coconuts2004
05-11-2005 04:24 AM
Quick Reply: How to replace transmission valve body?
