Intermittent wiper problem, ETACM
Old 03-21-2008, 11:35 AM
ace's Avatar
ace
ace is offline
Default Intermittent wiper problem, ETACM
I have a 1999 Elantra and the intermittent wiper control and park position does not work. The slow and fast speeds work fine. I have checked fuses and motor works fine (connected up spare working motor, and verified it worked, only on slow and fast wiper speeds as well). I do hear a "click" behind the ashtray (ETACM?) whenever I switch on the wipers for intermittent, slow or fast speeds.
According to the schematics the ETACM is responsible for the intermittent wiper, timing control, and auto parking. I need to first get to the module (in back of ashtray/radio), check the power to it, the grounding, and possibly replace it.
My question is which electronic module is it behind the radio, upper one or lower one? Each one has a multi-wire connector. Both boxes have a sticker label HMC One is stamped "AT" (w/18 wire connector) the other has a 20 wire connector. Any other concerns I should be aware of?
Thank you, ace
Old 04-06-2008, 05:04 PM
ace's Avatar
ace
ace is offline
Default RE: Intermittent wiper problem, ETACM
The problem was the ETACM. This was replaced and now the intermittent wiper control and park position work.
Ace
willbeck47
04-21-2015 05:07 AM
MeThoD87
12-05-2014 09:07 AM
Florida_Orange
07-10-2014 04:35 PM
rjs300
05-31-2011 09:57 PM
oncas
04-16-2011 12:48 PM
Quick Reply: Intermittent wiper problem, ETACM
