Recall Rust!!! 2001-2003 ELANTRA AND MY 2003 TIBURON
Old 07-02-2009, 11:47 PM
ken2400's Avatar
Default Recall Rust!!! 2001-2003 ELANTRA AND MY 2003 TIBURON
Well long story short
two new lower control arms and sway bar links.
whole new sub frame.
Looked at the sub frame after they pulled it off and basiclly I was able to remove one bolt and messed up the other. In the end time is $$ and the dealer got Hyundai to replace the frame sooo they cut all four bolts that go into the frame. So much for asking what the trick is to get them off. I think if I spent more time on the bolt nearest the front with more heat I would have backed it out.
Time to fix the CEL having to do with evap system and rust tank in the back.
Thanks and time to print the recall notes off and put them on all the 01-03 Elantras I see
Good luck with your.
Recall Date:
APR 16, 2009
Model Affected:
2001 HYUNDAI ELANTRA
Summary:
HYUNDAI IS RECALLING 170,610 MY 2001-2003 ELANTRA AND MY 2003 TIBURON VEHICLES ORIGINALLY SOLD IN OR CURRENTLY REGISTERED IN THE STATES OF CONNECTICUT, DELAWARE, ILLINOIS, INDIANA, IOWA, MAINE, MARYLAND, MASSACHUSETTS, MICHIGAN, MINNESOTA, MISSOURI, NEW HAMPSHIRE, NEW JERSEY, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, VERMONT, WEST VIRGINIA, WISCONSIN, AND THE DISTRICT OF COLUMBIA. ROAD SALT USED DURING THE WINTER MONTHS IN THESE JURISDICTIONS MAY RESULT IN INTERNAL CORROSION AND THINNING OF THE STEEL IN THE FRONT LOWER CONTROL ARMS. THE CORROSION MAY PROGRESS TO THE POINT WHERE THE LOWER CONTROL ARM'S UPPER AND LOWER PANELS BECOME PERFORATED. A PERFORATED FRONT LOWER CONTROL ARM MAY FRACTURE BETWEEN ITS BALL JOINT ATTACHMENT AND THE FORWARD AND REARWARD PIVOT ATTACHMENTS TO THE CHASSIS.
Consequence:
THE FRACTURING OF THE CONTROL ARM COULD AN OWNER¿S CONTROL OVER THEIR VEHICLE THAT MAY INCREASE THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT THE FRONT LOWER CONTROL ARMS FOR CORROSION DAMAGE. IF SPECIFIED LEVELS OF INTERNAL CORROSION DAMAGE ARE FOUND, THE FRONT LOWER CONTROL ARMS WILL BE REPLACED WITH NEW FRONT LOWER CONTROL ARMS INCORPORATING ADDITIONAL HOLES IN THE UPPER AND LOWER PANELS. IF THE FRONT LOWER CONTROL ARMS DO NOT REQUIRE REPLACEMENT, THE DEALER WILL ADD DRAINAGE HOLES TO THE FRONT LOWER CONTROL ARMS AND WILL TREAT THE FRONT LOWER CONTROL ARMS WITH RUST-PROOFING MATERIALS TO ARREST THE INTERNAL CORROSION PROCESS. THESE PROCEDURES WILL BE PERFORMED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2009. OWNERS MAY CONTACT THE HYUNDAI CUSTOMER ASSISTANCE CENTER AT 1-800-633-5151.
Potential Units Affected:
170610
Notes:
HYUNDAI MOTOR COMPANY 091
NovaResource
08-02-2019 10:54 AM
jadedangel421
02-29-2012 08:39 AM
seanathin48
11-30-2011 05:37 PM
sbr711
04-22-2010 07:04 AM
HocusPocus
03-03-2009 11:52 PM
Quick Reply: Recall Rust!!! 2001-2003 ELANTRA AND MY 2003 TIBURON
