To Remove Power Window Switch Drv Side
Have a problem raising and lowering the 2 rear windows from the drivers controller, with the lock/unlock switch in the unlock position there is nothing.
I can raise and lower both rear windows using the rear window switches.
The passenger side window can be controlled up and down using the driver side switch but the passenger side switch only raises the passenger window.
I want to start by removing the drivers side contoller and see if the contacts are clean. How is this removed without damaging anything. I'm thinking a finesse stick, and shouldn't have to remove the door panel? I can get the edge outboard to the door to lift slightly but it resists and I dont want to get too forceful, or should I?
It’s Very Easy to Install on a 2010 Elantra SE.
I was able to install the OEM power window main switch assembly in under 10 minutes on a 2010 Hyundai Elantra SE, shown here (
). The bezel contains only six screws and it does not seem it will easily break.
It’s about $47 on Amazon (https://amzn.to/2Kkha8K).
