Were is the Engine Control Relay Located?
#13
hi i have 1.8 j2 elantra no spark i did change coil crank sensor and plugs still no spark the wire that go to crank sensor got 3 wires there is no power on that wire
#14
hi im depressed my 1.8 elantra j2 just switch off while driving after searching the cause no spark i change coil and crank sensor and plugs still no spark it does crank but just dont want to start so the wire that go to crabk sensor got 3 wires must there be power on that wire bcoz we switch on ignition and fuel pump is pumping but there is no power on crank sensor wire coil wire power is ok power ia there
#15
Anytime you suspect there is a power supply problem, the first thing you should check is,,,, the fuses. In the vehicle owner's manual is a diagram and explanation of what each fuse protects and it's location. Saves a lot of time and trouble.
#16
hi thanks i did check the ecu fuse and all the other fuses in the engine bay and under the dashboard i even change the crank sensor the fuel pump relay the ecu relay but still no spark no injector pulse the fuel pump also is not pumping eish
#17
Please help
Can anyone help me out with a pic of where this relay is. I'm having the same issue with replacing of the coil , plugs , crank sensor etc etc but the car just won't start. I hear a constant clicking sound inside the car when I crank it. It has started a couple of times in the past but just dies a while later
