Hyundai i30 break light issue
Old 09-13-2016, 02:30 AM
Simon Ban-as Hother Hansen's Avatar
Default Hyundai i30 break light issue
Hi all
When i brake the top brake light turn on but the 2 brake lights on the side do not turn on. Have anyone experiences this?
I have read somewhere else that a reset of the ECU is enough to solve this?
Old 09-14-2016, 10:41 PM
avisitor's Avatar
Never heard of this brake light and ECU connection.
Usually the brake light circuits are independent of the ECU
Get a Haynes manual for your vehicle
Look at the electrical schematic for the brake system
It should show you whether it is hooked up with the ECU
Then, you can use a multi-meter or Digital Volt Meter (DVM) to test the circuit
Check to see if the brake lights are getting the 12 volts and that there is a ground or return path.
Old 09-21-2016, 07:56 AM
Obvious question: are the bulbs in the 2 brake lights on the side burned out?
The Gonz
08-19-2021 03:37 PM
jp10511
11-17-2011 10:32 AM
GoddessTink
11-02-2011 07:38 PM
f6typhoon
08-18-2010 04:39 PM
vincewturner
06-18-2007 05:40 PM
Quick Reply: Hyundai i30 break light issue
