Changing rear wiper blade
Simple task, simple question maybe - but can anyone give me an idea of how to change the rear wiper blade? Picked one up from the dealer when passing by (found a thread about cheaper options a few minutes ago...), checked the manual and it suggest the dealer do it to avoid damaging parts.
If you bought a factory blade it actually replaces part of the arm itself. Just lift the arm slightly and pull the blade and arm off away from the pivot point. Look at the replacement blade and you will see.
Here's a DIY for changing the rear wiper
Remove the cover from the rear wiper blade
Step #2 .. Use a 12 mm socket to remove the nut in the middle and pull off the wiper arm. Now, this is just like changing the blade on the front wiper.
Here's a quick photo of the receiving arm to hold the new blade.
You do not have to remove the wiper arm from the vehicle to change the blade.
Did a Tucson today, raise blade off widow, pop the tiny blade off, snap new blade on,,,,,, all done
ZombieHunter
12-09-2013 09:05 AM
