Hyundai Entourage This minivan boasts of being one of the safest vehicles in its class.
Front wipers in-op on intermittent and high rear wiper in-op also.
Old 02-04-2015, 05:45 PM
willbeck47's Avatar
Default Front wipers in-op on intermittent and high rear wiper in-op also.
Got a problem with a 2007 Entourage. Front wipers quit working on intermittent setting and high setting, speed one works fine except it won't park on it's own. You have to put it on and off until it is in the lowest position. Also the rear wiper is completely in-op. Replaced the wiper switch with a brand new one but did not resolve the issue. Checked fuses and they are all good.
Any help would be greatly appreciated.
Thank You.
Old 02-05-2015, 08:20 AM
Sounds like the motor itself, not the switch or fuse. The rear wiper is totally separate. Again, I'd suspect the motor.
Old 04-21-2015, 05:07 AM
willbeck47's Avatar
Default Issue resolved!
Finally the issue is resolved;
After trying a different wiper motor for the front and not having any change in the situation i trusted my gut and got another fusebox/bcm/ipm from a junkyard. installed it and everything works like it suppose to be.
Disassembled the old one and found 7 pins that goes to the connector for the multifunction swtich corroded and the solder deteriorated. The junk yard charged me $ 35 for the whole thing and that is a steal since hyundai charges a 6 bill or that part. Funny part is that there were no body codes found even that a part of that module was offline obviously not getting the wiper park signal from the front wiper motor. Thought i pass this information along.
globus999
09-23-2012 09:28 AM
seanathin48
11-30-2011 05:37 PM
MN220_3
11-02-2008 05:18 PM
ravensfan314
05-29-2008 09:35 PM
ace
04-06-2008 05:04 PM
Quick Reply: Front wipers in-op on intermittent and high rear wiper in-op also.
