Hyundai Entourage This minivan boasts of being one of the safest vehicles in its class.
P2187 and P2189 Codes CEL Illuminated
Old 03-05-2011, 05:22 PM
daveyoung1964's Avatar
Default P2187 and P2189 Codes CEL Illuminated
The check engine light illuminated in my wife's 2007 Hyundai Entourage. I checked for vacuum leaks. None found. Changed the MAF Sensor and I reset the computer. I allowed the van to warm up to operating temperature and drove it 30 miles with no check engine light. I parked the car in the driveway and allowed it to cool down for 2 hours. I then started the car and the check engine light immediately illuminated.
The following is the freeze frame data:
Parameter Description Results DTC for which Freeze Frame was Stored P2187 Fuel System 1 Status Closed Loop Fuel System 2 Status Not Supported Calculated LOAD Value 20.39 % Engine Coolant Temp 177.80 °F Short Term Fuel Trim - Bank 1 6.25 % Long Term Fuel Trim - Bank 1 25.00 % Short Term Fuel Trim - Bank 2 6.25 % Long Term Fuel Trim - Bank 2 25.00 % Intake Manifold Absolute Pressure 11.55 inHg Engine RPM 737.25 rpm Vehicle Speed Sensor 0.00 mph Ignition Timing Advance #1 Cylinder -2.00 ° Intake Air Temperature 66.20 °F Air Flow Rate Mass Air Flow Sensor 0.75 lb/min Absolute Throttle Position 15.69 % Oxygen Sensor Output Voltage (B1-S1) 0.75 V Short Term Fuel Trim (B1-S1) 6.25 % Oxygen Sensor Output Voltage (B1-S2) 1.20 V Short Term Fuel Trim (B1-S2) 99.22 % Oxygen Sensor Output Voltage (B2-S1) 0.77 V Short Term Fuel Trim (B2-S1) 6.25 % Oxygen Sensor Output Voltage (B2-S2) 1.12 V Short Term Fuel Trim (B2-S2) 99.22 % Commanded Evaporative Purge 0.00 % Fuel Level Input 19.22 % Distance since DTC Cleared 4.97 mi Barometric Pressure 29.31 inHg Control Module Voltage 14.05 V Absolute Load Value 20.39 % Commanded Equivalence Ratio 1.00 Relative Throttle Position 5.49 % Absolute Throttle Position B 16.08 % Accelerator Pedal Position D 15.29 % Accelerator Pedal Position E 7.45 % Commanded Throttle Actuator 7.45 %
P2187
Closed Loop
Not Supported
20.39 %
Engine Coolant Temp
177.80 °F
6.25 %
25.00 %
6.25 %
25.00 %
11.55 inHg
Engine RPM
737.25 rpm
0.00 mph
-2.00 °
66.20 °F
0.75 lb/min
15.69 %
0.75 V
6.25 %
1.20 V
99.22 %
0.77 V
6.25 %
1.12 V
99.22 %
0.00 %
Fuel Level Input
19.22 %
4.97 mi
Barometric Pressure
29.31 inHg
14.05 V
Absolute Load Value
20.39 %
1.00
5.49 %
16.08 %
15.29 %
7.45 %
7.45 %
Does anybody have suggestions as to possible cause of malfunction?
Old 03-05-2011, 06:49 PM
This is adding fuel to compensate...
By chance, you did not put any E-85 in it did you ??
Not seen or heard of them codes with any of the LAMBDA since they came out in 2006.
Did not buy regular gas that may be contaminated with excessive alcohol ??
No breaks in the boot between MAF and throttle body ?
How did you inspect for vacuum leaks ?
Old 03-06-2011, 12:59 PM
I only use regular unleaded or mid grade unleaded fuel. There is only one gas station in town that sells E-85. Tested for vacuum leaks, none found. We use only Exxon fuel. I have changed the MAF sensor. Inspected the intake duct and have not found any cracks tears or holes.
Old 04-02-2011, 06:08 PM
konrad_wrc's Avatar
I had an santa fe with an 2.7 and the intake plenum was leaking where you have the intake runner control the brass seal was leaking spray some brake cleaner or starting fluid as you manually move the shaft control back and forward. I work at a auto shop its called IRCM (INTAKE RUNNER CONTROL MANIFOLD) with codes P2187 and P2189 lean at idle bank 1 and bank 2
Old 08-24-2011, 03:50 PM
skinsfan05's Avatar
Did you ever find out what was wrong? I have the same two codes (P2187 & P2189) on my 07 Entourage with 85000+ miles. I also have code P0171 (System Too Lean Bank 1).
Old 08-24-2011, 05:23 PM
Back in October of 2010 my 2006 Kia Sedona (Entourage twin) with 53,000+ miles had a P0174 code (lean condition bank 2) and a P2187 code (lean condition at idle bank 1). The problem was a torn intake tube between the MAF and the throttle body. Kia replaced it for free under warranty. If you are the original owner, yours shodul still be covered under the 10y/100k mile warranty also.
degetel77
05-05-2015 01:48 PM
metalslayer
05-08-2013 12:59 PM
bbadger10
01-16-2013 03:04 PM
mitrals
01-17-2008 10:37 PM
duucfho
10-19-2007 11:55 PM
Quick Reply: P2187 and P2189 Codes CEL Illuminated
