Hyundai Genesis Coupe 2008-Present This rear wheel drive sports coupe offers a powerful V6, combining economy with performance.
2010 2.0T genesis coupe stalling
Old 08-19-2015, 06:24 PM
Anicholson1234's Avatar
Unhappy 2010 2.0T genesis coupe stalling
Hi guys, I have a 2010 Genesis coupe and almost every day it does not start at some point. Some times it just does not start and some times it starts but then within 10/20sec the revs drop and it stalls.
ODB reports p605 and p2105 error together but clears the CIM light by itself after a day or so. There is a tech bulletin out which says to replace the ECM module but I am not sure that this is the right fix.
Mode 6 data shows that a misfire did occur on cylinder 4 and another time it was captured on cylinder 1. I am suspicious that the evap monitor 0.090" is at -1432 and the max value is -1400 which makes me wonder if I have an evap problem.
Any suggestions to narrow the fault down?
Old 10-02-2015, 07:29 AM
quirkytones's Avatar
The problem can possibly be either a dirty fuel filter or a faulty O2 sensor. Have those inspected.
Old 10-02-2015, 01:34 PM
avisitor's Avatar
You need an ECM update
Needs to be done by the dealer
Believe there is a TSB (technical service bulletin) on this
When a P2105 occurs with a P0605
Was was for a Sonata?? Check with your dealer
Old 09-14-2018, 05:23 PM
Alfredo Neri's Avatar
Default 2011 genesis coupe 2.0t
I have a 2011 genesis coupe 2.0t that has a P0016 Code and doesn’t start up idk what the problem is anybody know what it is
905train
07-07-2014 02:38 PM
ata10
08-15-2012 03:53 AM
b5106
05-29-2011 11:26 AM
trev0006
02-15-2009 10:24 AM
trev0006
02-08-2009 09:45 AM
Quick Reply: 2010 2.0T genesis coupe stalling
