Getz hesitates on take off
Hi guys, I have a 2008 1.6 petrol Getz, great car but a few minor problems.
On take off it stutters a little at very low revs as you first let the clutch out, like a dodgy plug or lead.
Otherwise runs absolutely perfect.
I have put new plugs in and checked the resistance of the leads.
Cant work out though, it means in the manual by BOUG and R16AIPS?
resistance seems close to spec, looks like new NGK silicone leads on there.
Any other suggestions for stuff to check?
Its just a little annoying because my daughter is learning to drive in it and its harder to take off than it should be
Sticky injectors are slow to react to throttle
A bad TPS sensor would do the same hesitation
Cleaning out the throttle plate and intake plenum is a good place to start
But as you know, I can not see your engine so these are only guesses.
Santa Don
10-09-2012 08:58 PM
