Oil Drain Plug on a 1.1
I have a 2003 Hyundai Getz 1.1 and I'm about to do my first oil change. But I can't seem to find the oil drain plug anywhere. I've changed the oil on my motorcycle many times and that is a piece of cake. But on the Getz all the screws seem to be the same size. I do not want to remove the wrong one.
Any help would be appriciated.
never seen a car without a drain plug on the oil pan. if your lucky, the plug will have a little oil seepage also. helps finding the right plug. the bottom of the motor should have a drain pan or oil pan. engine block, oil pan, fairly standard layout. i don't think the pan is cast alum so it should be thin sheetmetal. just tap it and listen for a hollow sound.
thx1971
06-17-2009 07:19 AM
