2001 Hyundai Santa fe fuel filter/fuel pump replacement - Hyundai Forum - Hyundai Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 03-13-2010, 10:57 AM
Default 2001 Hyundai Santa fe fuel filter/fuel pump replacement
I ran my 01 2.4 L Santa fe out of gas and now it will not start. I don't hear the fuel pump running, so Im assuming it needs to be replaced. Where is it located, and what is the best way to replace it?
Thank you.
Old 03-13-2010, 12:31 PM
I dont think in 7yr I have seen a fuel pump ned replace in Santa Fe... though anything can happen
You can get to it by removing the left rear seat, unbolt it from floor and roll it into the rear cargo area.
From there you will semi-cutout portion of carpet, take razor blade and finish cut and through the foam pad, lay the flap and duct tape out of your way.
Remove black access cover, 4 screws I think.. lift and unplug connector off top of pump-filter-level sender module.. there is a bunch of screws around perimiter then, release the fuel lines, and lift module out of tank,,, though there will be a little turn here/lift here/twist to get it out..
But first we need to verify pump is getting power, so break out your trusty DVOM and verify power at connector, and power inside (we have seen terminal break at the plastic junction,,, power will be at connector, but not on otherside inside the tank where the fuel pump connector plugs in)....
Try hitting the reset button in the engine compartment, it is mounted to the left front strut tower, by the air filter box, has black rubber pad and round spot on pad about the size of a common thumb to push it.
2.4L,,, how is the timing belt/balance shaft belt ??? Seen a lot break the balance belt and the remnants "chunk" the crank angle sensor and it will not turn on fuel pump or injectors..
Old 07-16-2010, 06:19 AM
Before, you check the above, simply listen for the fuel pump relay to kick in when the ign sw is turned on, if no sound heard, check fuel pumpfuse. This is a 2 second job that might sve you the hardship of pulling out the fuel pump.
Reply
Thread Thread Starter Forum Replies Last Post
Fuel Filter & Fuel Tank Air Filter Paulus Hyundai Santa Fe 4 03-11-2013 10:29 AM
Fuel Filter and Fuel Tank Air Filter Location? Aggie_1990 Hyundai Sonata 7 01-17-2012 12:28 PM
2006 accent Fuel pump doesnt pump mcbakker100 Hyundai Accent 2 03-30-2011 01:47 PM
How do I change my fuel pump and filter on my 2000 hyundai elantra?? joker515 Hyundai Elantra 1 06-15-2010 07:45 AM
WTT: walbro 190 lph fuel pump for stock fuel pump 2loud2k2xd PRIVATE For Sale / Trade Classifieds 0 03-18-2006 07:38 PM
Tags
2000, 2001, access, fe, filte, filter, fuel, hyundai, installation, located, pump, santa, sante, tiburon, veracruz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
