2004 Santa Fe 3.5
Old 11-25-2008, 12:56 PM
v1vrfly's Avatar
Default 2004 Santa Fe 3.5
Hi,
I have a 2004 Santa Fe 3.5 with 145K mi.
This problem just came up. The car runs fine on the road but won't hold idle. it just drop to zero RPM and dies. It starts and will remain running with the excellerator. But the minut you lift off the excellerator it dies.
Any suggestions is appreciated. You can answer be back at v1vrfly@aol.com
Thanks
Greg
Old 11-25-2008, 01:23 PM
Rdturbulence's Avatar
Default RE: 2004 Santa Fe 3.5
TPS sensor, its right on the throttle body, i can almost garrentee that is the problem. My ex's car was doing the same thing, changed that, cleaned the throttle body and ran like new.
Here is the cheapest one i found on ebay -
http://cgi.ebay.com/ebaymotors/03-09...QQcmdZViewItem
Old 11-25-2008, 01:35 PM
Yes, I'd check the TPS first. Also consider checking the IAC (Idle Air Control) valve.
With the mileage you said, cleaning the MAF and/or throttle body would be a good idea too.
glassfern53
09-05-2015 02:47 PM
nhman
03-26-2008 03:55 PM
TATERTOTKC
09-05-2007 03:22 PM
jnezon@hotmail.com
08-13-2007 09:53 AM
larry139
03-11-2006 09:37 PM
Quick Reply: 2004 Santa Fe 3.5
