2009 Santa Fe
Old 03-05-2012, 08:33 AM
Hyundai newbie's Avatar
Unhappy 2009 Santa Fe
Help - I'm a new Santa Fe owner and am not familar with this vehicle. On the way to work this morning, the ABS & ESC light stays on and the light that shows all 4 wheels is flashing. What does this mean? I read on earlier posts something about a recall - could this be it?
Any suggestions would be great as I don't want to get "taken to the cleaners" by the repair shop.
Old 03-05-2012, 09:15 AM
It could be the brake light switch. Does your cruise control work? The flashing lights could be a low tire pressure warning. First check the tire pressures and then the TPMS system itself.
Old 03-05-2012, 05:40 PM
Okay - checked the air pressure in the tires and it's at 30, so that's not it. The lights went out for 5 minutes and then they are all back on.
Old 03-05-2012, 05:41 PM
Oh yes - the cruise control works
Old 03-05-2012, 06:16 PM
First, tires pressures should be at 33, not 30. So your tires are low. Tires lose 1 psi for every 10-deg drop in temp.
Are you sure the gauge is accurate?
I say go back to the dealer. It's still under warranty.
Old 03-07-2012, 12:12 PM
Smile
Update - dealer advises it is the Wheel Speed Sensor and it's under warranty! Whoo hoo, now just need to wait for the part to be ordered in.
Old 03-28-2021, 05:12 AM
Billyarbor's Avatar
Default Flashing lights
Had same problem after changing a wheel bearing! Put too much pressure on anti lock brake sensor. Check your sensors and replace bad one! Lights go away
encantotom
08-14-2016 07:50 PM
daniel2229
03-08-2014 07:16 PM
pats
11-22-2013 10:04 AM
pocahontas1960
03-06-2010 08:33 PM
mjusb
11-01-2006 12:18 AM
Quick Reply: 2009 Santa Fe
