2016 Santa Fe, Reverse Light Wire
I need to tap into the reverse light wire for a my 2016 santa fe in order for my surge brakes on my boat trailer to properly work while I am in reverse. I can only find the circuit in both the hood fuse panel and the actual reverse light compartment located in the hatch. Neither of these places are any good for running a wire back to my tow wiring harness. Does anyone know where I can tap into this wire. Does the wire from the hatch run over to the inside cargo area panel? If so, how do I remove that panel?
Reverse for surge brakes
Tekonsha 118269 4-Flat Tow Harness Wiring Package with Circuit Protected ModuLite HD Module
CURT 57187 4-Way to 5-Way Flat Adapter for Boat Trailer Surge Brakes
Plug up above headliner where I patched into the reverse wire.
reverse wires in the hatch at the back of the reverse light. Red is 12v for reverse
Route for the wire to the base of the rear hatch area.
