Another "Why won't it start" question.
Old 10-01-2007, 07:28 PM
Tennable's Avatar
Default Another "Why won't it start" question.
My 2004 Santa Fe starts but stops running immediatley. There is no visual damage, loose wires or anything I can see. Could this be a fuel pump problem?
Old 10-02-2007, 10:47 AM
Doohickie's Avatar
Default RE: Another "Why won't it start" question.
More likely a sensor problem... maybe crankshaft position sensor? throttle position?
Old 10-05-2007, 10:16 PM
Freddie's Avatar
Hyundai has some problems with the crankshaft posistion sensor. Located on the front of the block next to the starter on the V6.
Old 05-19-2008, 01:56 AM
I've got a 2002 4l Auto 2wd - same issue - starts up but only runs for exactly 3 seconds then dies. Did yours get fixed? What was causing the problem?
I already have a new Cam sensor, Crank sensor, spark plugs, and timing belt.
Michaels10
03-25-2011 04:37 PM
ernied
09-07-2009 11:36 AM
ETinCA
08-22-2009 02:31 PM
twospirits
12-30-2005 10:34 AM
GAVSKI
12-07-2005 03:26 PM
Quick Reply: Another "Why won't it start" question.
