Brake light/ blinker problem.
Old 08-21-2010, 01:44 AM
gumby25's Avatar
Default Brake light/ blinker problem.
Ok heres the deal. My right turn signal works fine unless the brake is pressed. The left works fine no problems. If the flashers are on and i press the brake the flashers stop on both sides. The brake lights work fine on both sides. Ive checked all the bulbs on both sides and everything is working fine. Its only a problem when im trying to use my right turn signal when the brake pedal is pressed the turn signal stops flashing and just lights up.
If anyone has had this same issue or might know what it would be itd be a huge help. I was thinking maybe the turn signal relay or maybe the brake switch...
Old 08-21-2010, 05:26 PM
A bulb is bad. Did you check ALL the bulbs? Not just the ones in the tail lights. Check the front and side signal bulbs too.
Old 08-21-2010, 11:25 PM
dunkyd's Avatar
Please post solution when you find it. That's the purpose of a forum. Sure sounds like one bulb in the system is shorting.
Old 08-22-2010, 07:43 PM
gumby25's Avatar
All bulbs have been replaced with the correct bulbs and are working. So i dont think its a bulb. Anyone else???
Old 08-22-2010, 09:53 PM
Just to calarify, did you check the front and side turn signal bulbs?
Old 08-24-2010, 12:06 AM
gumby25's Avatar
Nova are you being serious??? How many times do i have to say that YES i have checked all of the lights!!! All light bulbs are working. So does anyone else have any suggestions besides "check the bulbs"?
Old 08-24-2010, 03:21 AM
dunkyd's Avatar
No we don't.
Old 08-24-2010, 06:42 AM
I'm trying to answer your question and I was looking for more information because your posts were unclear. If you don't like it you can look elsewhere for your answer. Lose the attitude.
IcantDo55
02-16-2014 06:37 PM
Log2
03-01-2012 09:52 PM
wicked5.0
03-13-2011 04:26 PM
Jon
07-23-2010 09:28 PM
Quick Reply: Brake light/ blinker problem.
