Front & Rear wheel bearings - Hyundai Forum - Hyundai Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 08-11-2010, 12:55 AM
Default Front & Rear wheel bearings
Can anyone tell me how hard of a job it is to replace the front and rear wheel bearings on a 2004 Santa Fe 3.5 AWD LX? If anyone has any information or manual excerpts, that could be of great help.
Old 08-11-2010, 07:37 AM
REMOVAL
1.Raise the vehicle and remove the front wheel.
2.Remove the wheel speed sensor from the knuckle.
3.Remove the brake caliper and suspend it with a wire.
4.Remove the split pin, the castle nut and the washer from the front hub.
5.Remove the strut and the two bolts mounting the knuckle.
6.Disconnect the tie rod end ball joint from the knuckle using the special tool (09568-34000).
7.Remove the lower arm ball joint mounting bolt.
8.Using a plastic hammer, drive out the axle hub from the driveshaft.
9.Remove the front axle assembly.
DISASSEMBLY
1.Remove the brake disc from the hub.
2.Remove the snap ring.
3.Remove the hub from the knuckle using the special tools (09517-21500, 09517-3A000, 09517-29000).
A.Install the special tool to the hub and knuckle.
B.Tighten the nut of the special tool to disconnect the hub from the knuckle.
4.Using the special tools (09455-21000, 09545-34100), remove the wheel bearing inner race from the hub.
5.Using the special tools (09532-32000, 09216-22100), remove the wheel bearing outer race from the knuckle.
INSPECTION
1.Check the hub for cracks and check the splines for wear.
2.Check the hub bolts for cracks and damage.
3.Check the brake disc for scoring and damage.
4.Check the knuckle for cracks.
5.Check the bearings for defects.
REASSEMBLY
1.Apply a thin coat of multi-purpose grease to the surface of the knuckle and bearing.
2.Using the special tool, press the bearing onto the knuckle.
Press-in load [kg(f), (lb(f))] : 4500~5000 (9921~11023)
• Do not press against the outer race of the wheel bearing because that can cause damage to the bearing assembly.
• Always use a new bearing assembly.
3.Install the snap ring into the groove of the knuckle.
4.Install the backing plate to the knuckle.
5.Press the hub onto the knuckle using a special tool.
Press-in load [kg(f), (lb(f))] : 2000~2500(4409~5512)
Do not press against the outer race of the wheel bearing because this can cause damage to the bearing assembly.
6.Rotate the hub several times while seating the bearing.
7.Measure the wheel bearing starting torque.
Wheel bearing starting torque [Limit]
1.8 Nm (18 kgfcm, 1.3 lbfft) or less
8.Measure the end play of the hub by installing a dial gauge and verify that it is within specifications.
Hub end play : 0.064 ~ 0.088 mm (0.0025 ~ 0.0035 in.)
9.Remove the dial gauge.
10.Install the disc to the hub.
Reply
Thread Thread Starter Forum Replies Last Post
97 Elantra rear wheel Bearings Needyspeedy Hyundai Elantra 0 06-10-2011 07:35 AM
Front wheel bearings maddog0418 Hyundai Tucson 2 02-22-2011 07:41 AM
03 elantra front wheel bearings.... noroll Hyundai Elantra 0 01-22-2011 08:26 AM
2003 Accent Front Wheel Bearings ccacioppo Hyundai Accent 11 04-22-2008 09:00 PM
02 Elantra Front Wheel Bearings euler Hyundai Elantra 2 03-18-2008 11:39 PM
Tags
2004, awd, bearing, fe, front, hyundia, installing, installlation, press, rear, removal, remove, sanata, santa, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
