Intermittent Cylinder #2 Misfire
Old 02-15-2011, 07:16 AM
santafestan's Avatar
Default Intermittent Cylinder #2 Misfire
My daughter's 2003 Hyundai Santa Fe with a V-6 and 186,000 miles on it has developed an intermittment misfire on cylinder #2.
She called me this past Friday night and I drove up to her place, hooked up my Auto Tap and was told that cylinder #2 had a misfire. I opened the hood, shut the engine down and was about to remove the engine cover and check the spark plug wire and spark plug.
Prior to doing that, I wanted to clear the codes, so I reached in started teh engine up and it was smooth as glass. I checked and the cylinder #2 misfire was gone.
This morning my daughter called and said it was 'running bad' once again.
Now, this morning is cold (we're in Florida so 'cold' is a relative term) at about 45 degrees. On Saturday it was nice and warm and sunny, about 70. I'm king of wondering if I need new spark plugs and also wire as they might be holding moisture and causing the misfires.
Anyone else have anything similar?
Thanks for the response.
Old 02-15-2011, 07:46 AM
Have the plugs or wires ever been changed?
Old 02-15-2011, 08:37 AM
I'm not sure. However that is where I was going to start.
Does the 2003 2.4 V-6 have spark plug wires or plug and coil technology?
I need to pick up a manual to find out. I'm heading there later today.
Old 02-15-2011, 09:15 AM
The 2.4L engine is not a V6, it's an in-line 4-cylinder. So what do you have, a 2.4L 4-cylinder or a V6 (2.7L or 3.5L)?
And all gasoline engines have "plug and coil" technology. What I think you are trying it ask is if it has a remote coil with plug wires or "coil-on-plug" technology (aka direct ignition).
Manuals are available online here http://www.hmaservice.com but based on your posts, I'd suggest going to a qualified mechanic.
Old 02-15-2011, 09:28 AM
I know for sure that it's a V-6 engine. I'm going on what my daughter told me about the engine size. However I have been looking for parts and they all list the 2.7, so I'm assuming that she was incorrect.
Not long ago, I had replaced the serpentine belt on the car and that's how I know it is a V-6 as I saw a lot of underhood time during that.
My son is buying a manual this AM, so I should have some reference material to go by.
From what I saw on Saturday, it looks like I need to remove the intake plenum to gain access to the rear spark plugs. Is that true?
My 'Foreign Built Car' was a whole lot easier to work on. A 1974 Dodge Colt that I put a 372 cubic inch Mopar small block into with W-2 heads. A few Dzus fasteners and the entire front clip could be removed.
Old 02-15-2011, 09:59 AM
That is correct. The upper half needs to be removed and I'd suggest replacing the gasket.
Old 02-15-2011, 10:26 AM
Any other gaskets?
I would hate to induce another 'issue' with a vacuum leak!
Jesse James
03-27-2011 08:25 AM
AleshaM
01-27-2011 10:08 PM
kittehs4peace
01-11-2011 11:16 AM
40thEd
10-21-2008 10:18 PM
tvlodek
02-20-2007 01:33 PM
Quick Reply: Intermittent Cylinder #2 Misfire
