multiple codes on a 2002 santa fe 2.7. v6
Old 02-06-2015, 11:16 PM
theredtick's Avatar
Exclamation multiple codes on a 2002 santa fe 2.7. v6
I was driving on the highway and the MIL came on. When I got home I decided to scan it. Too many codes!!
P0174 P0171 System Too Lean Bank 1 and 2
p1167 p1166 O2 Sensor System Lambda Controller at the Limit Bank 1 and 2
p0455 p0442 EVAP Emission System Leak Detected Large and small Leak
I did a visual inspection and everything looks ok. Any ideas????
Old 02-08-2015, 03:47 PM
Looks like there is a large vacuum leak in the EVAP system which is leaning out the fuel mixture. Better have the EVAP system smoked to find the leak.
Old 03-01-2015, 03:02 PM
theredtick's Avatar
Thumbs up yauzza!
Thanks NovaResource I smoked the intake myself and found that the throttle body ($40 at the salvage yard.) was leaking from the seal of shaft that opens the throttle plate. And I also replaced the purge valve and that fixes two other o2 limit codes that were showing up after I changed the throttle. No codes!
Old 03-02-2015, 02:23 PM
Nice work!
husky
10-14-2009 11:10 PM
jim tjernlund
08-26-2009 07:37 AM
JLF
05-13-2007 06:06 PM
rollerdawg
08-09-2006 07:32 PM
Quick Reply: multiple codes on a 2002 santa fe 2.7. v6
