power steering pump proplem
Old 08-13-2010, 09:00 AM
samer haddad's Avatar
Default power steering pump proplem
hi....
i drives a 2005 Sante Fe v6 2.7 4#4 and it's constantly groaning and the oil is pumping out of the reservoir cover and the oil have bubbles running with it. i replace the pump before it dies on Has anybody attempted this that could give me some pointers?
thxxxxxxxxxxxxx
Old 08-13-2010, 06:15 PM
Remove the bottle and clean it... there is a fine mesh screen it it that is lekely clogged... if that dont work, replace it.
Old 08-14-2010, 03:45 PM
thank you >> i did clean it .....nothing happend? so some one make some small holes in the screen to make the oil flow in v.good ( as he claimed ) but nothing changed???
Old 08-14-2010, 03:47 PM
dose the 24 hose get closed??????? so the oil donot flow well???
Old 08-14-2010, 04:06 PM
Text from TSB :
DESCRIPTION:
Before replacing a power steering oil pump for a "whine" noise condition, check the oil
pump reservoir filter screen for contamination. If the filter screen at the bottom of the oil pump reservoir is clogged, it may cause the pump to aerate and cause a "whine" noise.
If the filter screen is clogged, replace the reservoir and reconfirm the condition.
daughters1stcar
12-02-2010 11:30 PM
Tiburon7269
05-21-2010 04:21 PM
P.D.
11-05-2009 09:02 AM
fbnewtz
07-19-2008 07:31 PM
90excelGS
04-04-2008 04:19 PM
Quick Reply: power steering pump proplem
