Replacing Rear Taillight
How do you replace the tail light bulb on the left rear of the '07 Sante Fe. The one on the outside fender. There is a access panel in the back but it does not seem to have access to the light cluster
Thx
Thx
The access pannel is not for the bulbs, it's for the screws that holds the light housing to the body. You remove those screws and then pull the housing off the nody. Once the housing is off, you can then access the bulbs.
1.Loose the screws (3EA) holding the rear combination lamp then disconnect the 4P connector then remove the outside rear combination lamp.
2.Replace the bulbs (3EA) after disconnecting the rear combination lamp assembly.
FL ROD
05-01-2008 11:43 PM
