2 Quarts of Red Line
Old 07-27-2009, 10:58 AM
vainisac's Avatar
Default 2 Quarts of Red Line
I have two quarts of "Red Line MTL" API GL-4 Gear Oil (SAE 70W80) will this work with my 2000 Sonata 2.4 manual?
http://www.uucmotorwerks.com/catalog...70w80-gl-4.htm
If so do I need to fully drain the transmission before using the "Red Line" a.k.a. will it mix with my current fluid if I drain some and not all.
Thank You.
Old 07-28-2009, 05:35 AM
jsinton's Avatar
Banned
I'm sure it would work, it's just that it's not the recommended stuff. You're supposed to use synthetic 75-90 stuff. The other thing is you probably need 2 1/2 quarts. It should mix with no trouble.
Old 07-29-2009, 07:14 AM
vainisac's Avatar
Default That you for that information.
Will the friction coefficient of Red Line MTL work in the (2000 Sonata) transmission. Accelerated syncro wear is something I would definitely want to avoid.
Thanks
Old 07-29-2009, 10:44 AM
jsinton's Avatar
Banned
Frankly, I wouldn't worry about it unless you plan on slamming gears and driving like an idiot. But if you really want to worry, then spring $12 for the correct stuff.
Old 07-30-2009, 10:20 AM
vainisac's Avatar
Default That has quelled most of my anxieties.
Sounds good thanks jsinton.
wee-haggis
09-14-2009 05:14 PM
rfairorth66
10-26-2008 02:25 PM
CaptAthlon
08-13-2007 12:38 PM
himatrix
08-04-2007 10:31 PM
iguana8334
12-19-2005 05:12 PM
Quick Reply: 2 Quarts of Red Line
