2011 Sonata SE Steering Problem
#81
#82
-----> YF Sonata (2011)
NOTE --> tell your dealer that when they do the program.................... have the GDS on the dock station and plugged into the wall while programing...... I wont go into details about a certain car at our place.
It is program #207
#83
Program has nothing to do with steering pull. According to recall instructions should be on dock station anyway along with hardlined using usb cable with battery within proper voltage. This recall is an inspection with EPS reflash. I did 10 today...takes less than 15 minutes per vehicle reflash is longest part.
#84
It wasn't me... they tried to give me 1 while other tech had them lined up, I told them let him do them so we dont get into GDS war...
Did you get the GDS economy kit ?
#85
GDS light...yea but we dont use it . Usually only need reg GDS in shop
#86
Just go over train tracks at around 10mph, preferably tracks running diagonal to the road. It seems to be related to uneveness in the road between the two front wheels.
I think I've also been able to replicate it while sitting still and moving the steering wheel when it's turned a certain amount, will let you all know soon.
I agree with a few others here, this should be reported since all reports are escalated to Hyundai and if there's commonality they will research.
#87
I have found that with the car off and the wheel turned a turn to the left or right that I can reproduce the "steering wheel rattle" by quickly moving the wheel back and forth (not wildly, just an inch of travel or so).
It seems to me to come from that area of the steering.
Also, it does seem to happen more while mildly braking.
#88
#89
#90
Links for 2011 Hyundai Sonata recall:
http://www.washingtonpost.com/wp-dyn...=moreheadlines
http://www-odi.nhtsa.dot.gov/recalls...intVersion=YES
