2015 Sonata bumper cover loose at rear wheel!
Old 09-14-2016, 09:05 AM
stillcreative's Avatar
Default 2015 Sonata bumper cover loose at rear wheel!
I noticed that the rear bumper cover just behind my passenger side wheel is loose. I can move it back and forth. I replaced one of the two retaining nuts/clips that holds the inner fender liner in place, but when I move the b-cover, the liner just slides back and forth with it. The retaining nuts aren't doing it's job. Has anyone had this issue before? Does anyone have any input to fix this?
Old 09-14-2016, 10:43 PM
avisitor's Avatar
So you put new retaining nuts/clips in
Did you put in a new bolt to lock the two parts together??
Old 09-15-2016, 06:56 AM
The stud was spot welded by the factory, all you have to do is push the new plastic nut until it stops clicking.
Old 09-15-2016, 10:35 PM
avisitor's Avatar
Sorry, can't help you.
On my 2001 Elantra, the rust was so bad that those spots where it is held together were almost gone.
I simply put epoxy steel on it and smoothed it out.
Then put nuts and bolts through that to keep the rear bumper to the fender.
Doesn't look great. But, it works.
Wish you luck on finding a fix
Old 09-16-2016, 08:28 AM
Thanks anyways! I might try something like liquid nail to keep it from shifting back and forth!
LaurainTampa
03-16-2021 02:50 PM
bobjhunn
10-09-2017 10:17 PM
Kayak12
07-15-2009 09:14 AM
mattcg1
02-13-2008 01:52 AM
chirc
03-03-2007 02:44 PM
Quick Reply: 2015 Sonata bumper cover loose at rear wheel!
