Auto trans input output speed sensor?
#1 is the wire harness connector (18 pin connector) for the trans solenoids/speed sensors/fluid temp sensor.... all of which is located inside the actual transmission case.
You want speed sensors, you will have to go inside the trans case to get at them. They are not external like previous editions.
