Crankshaft position sensor
Old 01-07-2008, 05:09 PM
gussetgus's Avatar
Default Crankshaft position sensor
Hey all newb here. I have a 02 sonata with the 2.4 in it. Have had the car since new and its been a great car. Now it will only run for a couple of minutes then shuts off. Anyway I plug the code reader in and comes up po335 crankshaft position sensor. Where is the sensor located?
Old 01-08-2008, 09:20 AM
Doohickie's Avatar
Default RE: Crankshaft position sensor
This photo shows the electrical connector for the sensor:
Old 01-08-2008, 10:59 AM
gussetgus's Avatar
Thanks. I was able to find its location at the hyundai tech site. Let me tell you it is a pain in the a$$ to get to. Had to remove power steering pump, crank pully and alt pully just to get to the bolts for the lower cover. Also had to remove the timing belt to get the sensor out. There is just no room to work on it. took me 3 hrs just to get it out.[:@]
Old 03-29-2009, 02:08 PM
PAPMECH's Avatar
My 2000 elantra shows po335 crankshaft position sensor (a) circut malfunction ant ideas, and which one is sensor (a) i see oneunderneath the intake manifold and one at the lower rear of the of the block in the front.
Thanks
Old 03-29-2009, 09:19 PM
jsinton's Avatar
Banned
It's probably your crankshaft position sensor going bad. It's really common. It's the one underneath. The one on the head is the camshaft position sensor.
Old 04-06-2009, 06:02 PM
mmohr's Avatar
Default Hyundai Sonata 2000
I had my car checked and the computer said it was the crankshaft censor that was going bad. I just changed the censor, the car started before I changed it, but now it turns over and acts as if it has no spark. PLEASE ANY ADVISE FROM ANYONE WOULD BE GREAT!!!
Old 04-06-2009, 06:21 PM
jsinton's Avatar
Banned
Sometimes the old gasket gets stuck in the hole when you pull the old sensor. If the old gasket remains in the hole, and you put a new gasket in, it makes too much clearance and the magnetic pickup won't get a signal. Other than that, maybe the new one is DOA, which happened to a guy last month. If all else fails, put the old one back in and test it.
Old 01-21-2011, 02:47 PM
thebitworks's Avatar
Default Keeping Hyundai Afloat by Purchasing Camshaft Position Sensors
Hi All,
I am searching for ideas, ordered the 4th camshaft position sensor in the last year from local napa parts outlet. I was wondering if anyone else was having this problem, the ones I put in seem to last 3-4 months then go out. Engine dies, throws a code P340 and then either won't run or runs like crap.
Last time I replaced the coils as well thinking that would do the trick, but now luck, wife just called and she is dead at work, so planning on putting a new one in again tonight.
The longer term question is of course how long before I am doing this again? Should I just by a half-dozen instead of one?
All of this seemed to start after the car threw the timing belt and I replaced it, along with rebuilding 1/2 the engine. It seemed to run fine for about three months then just died with code P340, $80 later we were back on the road, again lasted about 3 months and croaked, and so the cycle goes on.
I am wondering if the timing is just a little bit off and could be causing these to fail prematurely, or is there a possibility we are loosing some cam bearings or something like that? Anyone experienced a similar issue? If so, some pointers would be helpful.
Old 02-05-2011, 03:19 PM
Default Got 2 weeks out of another new one
Anyone have any ideas on this, I just got a whole 2 weeks out of a new sensor from Napa.
Old 02-05-2011, 06:26 PM
Buy a sensor from Hyundai parts dept, as it comes from an approved Hyundai supplier...
Pedro_Brazil
06-25-2012 05:15 PM
hurricanechow
06-12-2009 12:40 PM
jpy102002
01-19-2009 08:40 PM
letsscuba1977
11-28-2008 07:11 AM
Quick Reply: Crankshaft position sensor
