Air Con intermittent failure Sonata
Old 08-21-2012, 04:54 PM
gcleeton's Avatar
Default Air Con intermittent failure Sonata
Sonata SE 2012 16K miles. On two occasions when switched to Air Con, it has blown hot air. If I stopped the engine and started it again the Air Con came on. Any ideas please? Gil
Old 08-28-2012, 08:58 AM
blh7068's Avatar
Well...being only two times, I gotta ask- are you sure you actually engaged the A/C? Also, if the car has been sitting, its going to blow hot when you first turn it on...and when you first do that make sure its not on recirc- as the air in the car will be hotter than outside. Also, if youre not in recirc and you come to a light, the A/C wont be as hot since its pulling heat from the engine when stopped for those couple of moments.
See if it becomes more frequent...if it does then take it in for service...otherwise, the dealer wont due anything if they cant reproduce the problem. GL.
kirko
01-15-2013 05:28 PM
rosen68
05-29-2011 12:49 PM
beachsands
05-22-2007 01:06 PM
NGHII
03-20-2007 09:00 AM
normski24
09-22-2006 02:57 PM
Quick Reply: Air Con intermittent failure Sonata
